wa8yxm
May 31, 2022Explorer III
Actually the 20 dollar mercury free mechanical analog T-Stat From ACE hardware (What I used) may well be better than the electronic ones for use with the Furnace... I only used it for the furnace. (Mine was the "heat only" model)
For A/C you may need an electronic stat (or not depending on the A/C but for the furnace that 20 buck job is perfect.
I did add a toggle switch in series with it so that I could HARD off the furnace.
But I liked it better than the factory T-Stat.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
