DrewE
Oct 07, 2018Explorer II
Basically any stove with a regulator you can remove/bypass will work. If the controls and regulator are built into a single doohicky that also attaches to the propane can or cylinder, you're out of luck. I think most multi-burner stoves or grills would be more or less straightforward to convert (depending on how accessible the regulator is, and how it connects to the rest of the unit).
