tandkj wrote: I use the spray foam stuff in the red can to lube and clean the seal flaps.
Cuse me sir. I Googled "spray foam stuff in the red can" and nuttin but foam insulation popped up. Would you mind telling what spray lube you use comes in a red can. Inquiring minds want to know.
Janet & Milo ...47 fantastic yrs 2gether :B Mona Yorkie & Buddy our beloved Beagle (both in spirit) 2013 F-150 Kodiak Brown XLT 4X4 HD Ecoboost 2014 Cougar 26sab Living under the best Government money can buy ... Bob Brinker ๐
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast. 08 Camelot Custom build 07 Ranger Toad One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
If you are referring to the rubber wipers, not seals, on the outside of the RV any good rubber protectant such as 303 works fine. If you mean the seals which are on the inside, talcum powder works great to keep them from sticking. The rubber wipers are designed to clean the slide as it retracts.
