precioustime's avatar
precioustime
May 20, 2018
Lubricating the Push-Pull Black Water Valve?
My Storm 28MS has the standard push pull valve to empty the waste in the tank. At times it is difficult to pull and push that handle on the valve. Anyway to lubricate that valve? I saw a video once that said I could drill a small hole above the opening and attach a flat pan head screw in order to spray the inside of the valve with WD-40 or some other lubricant then attach the screw back. Another article said to pour some liquid in the kitchen sink. Of course both of these ideas are done after the tank has been drained. any suggestions?
