โOct-11-2017 10:23 AM
โOct-14-2017 04:05 AM
D.E.Bishop wrote:
I have never had a macerator but I have had and used a stinky slinky and a SS, both do the job at dump stations but the cleanout at my home is 20 feet away and about a foot up from the grade the hose sits on and the SS has been a money saver and made life easier. The biggest problem is the moving parts and the hook up mount are plastic and they do age and break.
I saw the garbage disposal macerator on this site some time ago and downloaded it for a future project. Because I will only use it at home, size, 120vac and storage is not a problem. At campgrounds with dumps o FHUs, the stinky slinky is all I need.
โOct-13-2017 10:36 PM
โOct-13-2017 09:42 PM
SoundGuy wrote:Ron3rd wrote:
X2 on Sewer Solution, basically a water powered macerator. I dump at home through a clean out about 60 ft away through a 3/4" hose.
But useless for those of us who may want to also use the macerator while camping where no water under pressure is available to power a Sewer Solution, a problem not shared by the 12 vdc powered FloJet Waste Macerator. ๐
โOct-13-2017 08:25 AM
โOct-13-2017 07:02 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โOct-13-2017 03:02 AM
Dtank wrote:SoundGuy wrote:Jayco-noslide wrote:
My son has one and he'll tell you it's just great but, for the life of me, I can't figure out why I need this extra piece of equipment to haul, take up space and mess with dumping. I pull up to the dump, hook up the hose, pull the valves and it whooshes out in about 1 minute.
Simple - some of us have no interest in wasting our time lining up at a dump station ... ever. :W
"Some"...- (or "a few")....:h
Or none ..... 'cause -
Some (or a few) of "us" don't waste our time when there's a line .... ever.
Only difficult if you want it to be..:R
โOct-12-2017 11:59 PM
Kayteg1 wrote:No sense of humor today?2oldman wrote:Kayteg1 wrote:Somehow I don't think that is a problem for the folks on this board. Maybe when their grandchildren visit.
..Condoms do.They are one of the biggest problem in city sewer treatment plants.Called "silver fish" by the workers.
Does it matter who dropped it in?
Just think what you'd do when that thing ends in your macerator pump.
โOct-12-2017 09:22 PM
Kayteg1 wrote:2oldman wrote:Kayteg1 wrote:Somehow I don't think that is a problem for the folks on this board. Maybe when their grandchildren visit.
โOct-12-2017 08:58 PM
โOct-12-2017 04:58 PM
โOct-12-2017 04:15 PM
โOct-12-2017 03:24 PM
wa8yxm wrote:
now the macerator
The one and only comnplaint (And the solution) is that if it's not used often adn I mean often it develops "Sticktion" that is the impeller blades stick to the pump housing and when you turn it on POP goes the fuse.
Solution .. On the non-pump end of the motor is a slotted shaft.. Use a quarter or any flat tool to turn it one rotation, this cures the problem 100%
โOct-12-2017 11:34 AM
โOct-12-2017 09:07 AM
wa8yxm wrote:I have had that problem three or four times. Unfortunately, two times I turned the motor the wrong direction and broke the impeller each time. I learned that after using the pump, a half of teaspoon of any oil in the macerator prevents the impeller from sticking. I also painted a large white arrow showing the direction of rotation.
When I need it.. I'm very glad I have it.
Toad: 91 Zuke
