Ron_Schulz
Oct 10, 2015Explorer
Welcome to the forum inderocker.
The problem can be anything from a restricted main burner orifice to a thermostat needing adjustment. Carefully remove the burner orifice and see if anything is in there. Spiders love to build nests in that area. While measuring the oven temp., carefully open up the bypass screw on the thermostat a little at a time to get a larger main burner flame. This is a time consuming process but if the orifice is clean than the thermostat is where your problem would be.
Good luck.
Good luck.
