greenno
Mar 20, 2023Explorer
Having (2) 6 volt battery's connected in parallel is part of your problem.
Im sure you meant series connections for your 12v system correct?
Battery's have probably reached their lifespan but that's just me.
Since you have had an ongoing alignment issue thats probably key to your motor glitch.
Maybe that motor isn't properly aligned and it causes it to bind when retracting back in causing a small OL and then when load is off breaker resets until you do it again.
Find a good Electrician and have him check your amperage draw on that motor when it shuts off, probably drawing more than it should.
