pmbarber's avatar
pmbarber
Major Issue with Lippert 2X2 electric through frame slideout
Jayco JayFlight 26BHS- Full Slide- Dinette and Living area
Hello. On a recent camping trip when we extended our slide we noticed that the rear of the slide was not extending out even with the front. We also noticed a loud popping sound had began when extending and retracting the slide. We managed to get through the trip and get back home. Upon inspecting the system I noticed one of the teeth on the front gear (15 tooth gear) was broke off. I replaced the gear, aligned the slide and was hoping this would fix the issue. OF course that is not my luck. The slide retracts nice and smooth, however, once it gets about a 2 foot from sealing the popping starts. The popping is caused by the inner arm assembly raising up on the gear and then slamming back down. Once this happens the teeth on gear and rail are slipping, which causes the rear of the slide to get misaligned again. This process repeats itself. I have have a couple links showing video of my issue if anyone wouldn't mind taking a look to help diagnose the issue.
Front rail assembly- gear pack moving along the track
Inner arm assembly being retracted, nearing the end of the track
Thank you in advance for your help.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 21, 2026
