splegge
May 18, 2014Explorer
Max Air II vent to low to roof - rubbing
Hi all,
Installed max air II vent last fall. had clearance 1/8 -1/4 inch all the way around so no edges wear contacting roof. After cleaning and inspecting I see the rear of the cover is contacting my roof. My thoughts are it will wear a hole or tear ......
has anybody else had this problem?
Thoughts on raising or bending it up or pop the cover open and dremel 1/4 to 1/2 inch off the bottom?
