greenrvgreen's avatar
greenrvgreen
Meanwell is here!!
Ordered a Meanwell SP-200-15 from Jameco on Thursday, it arrived Saturday, looking all shiney and new. Here is the link to the listing on Jameco:
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_202060_-1
And here is a link to the PDF data sheet from that listing:
http://www.jameco.com/Jameco/Products/ProdDS/202060.pdf
This morning I performed the unboxing and setup, and now I have some questions.
--Using a reliable multimeter on the 15V studs, I get an adjustable voltage range of 12.6v to 17.5v. It is the same under no load and a light load (LED lamp). The specs state a voltage range of 14.3 to 16.5. Did I just get an early Christmas gift with this wider voltage range?
--I have not clamped it to my battery bank yet. First I want to get an idea of best practice for charging. Am I right that I should first verify and/or adjust the voltage on the Meanwell (14.6 for AGM?) with no load, and then monitor the voltage at the battery as it climbs? And what would be my target voltage at the battery?
--Since it seems I now have the capability to ease down to a Stage 2 (or float) charge, can I get a reliable voltage reading at the Meanwell 15v studs while it's connected to the batteries, or will the 14.6 output voltage of the meanwell already be equalized to the voltage of the batteries at the studs?
Battery bank is 100ah - 160ah (depending on config), AGM batts.
Meanwell is 13A output, level (14.6v) output unless manually adjusted.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
