MEXICOWANDERER's avatar
Jun 25, 2018
Meanwell RSP 1500-15 147 Amps Into 12 Volts WOW!
I did a full-0n load test this morning, because I finally got my adjustable carbon pile load tester back. Both a Manganin shunt plus 5-digit voltmeter and a DMM inductive ammeter confirmed the amperage.
Hah! Now I need to force-feed the unit with cooler air. Well, I purchased a variety of Landyacht's recommended fans.
This is not my charger. It's for a friend. It will be mated to a 5500 watt generator on the 30 amp 120 volt receptacle.
I wonder if those thermometers that are used for refrigerators and freezers are dependable enough to use for monitoring? I would need an IP67 model. Waterproof. Thank god this critter is destined to go to the high latitudes...
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
