MrWizard
Mar 09, 2018Moderator
Fridge runs off the propane.
I started up the coffee maker without the engine running so I could see the draw.
I'm using about 900W, 75A with it running and batteries holding at 12.4 V
remote display on the inverter is showing a 50% output which is too high.
http://gpelectric.com/products/3000-watt-pure-sine-wave-inverter
3000W continuous, 6000W surge.
that is your clue
you need another meter, to verify the 75 amps load
either the inverter is drawing more,
or the control sensing circuit 'thinks' you are using more
so when you try to use the MW the controls module shuts you down
i think you are going to need to replace the inverter
is it still within warranty ?
