pianotuna's avatar
pianotuna
Nomad III
Oct 03, 2022
microwave replacement
Hi All,
My Dometic microwave turn table has died.
I do have a capable 3000 watt psw inverter.
What would you choose to replace it?
I'm tempted to just use it without the turntable.
I might gain a little storage by replacing it.
  • wa8yxm's avatar
    wa8yxm
    IAMICHABOD wrote:
    You can replace that turn table motor fairly easy,I have done 3.
    They have many replacements on Amazon
    Dometic... I do not know about yours but Mine was made by LG (Lucky Goldstar) and I have not been all that Lucky with Goldstar products.. Long story omitted.. So far I've had just one that works. I avoid them.
    Now the microwave.. The problem it had was the turntable motor. the plastic shaft was just flat too short. in addition the hole the 3 arm went through to engage the motor.. Too small.
    The solution.. GE uses the same motor but it has a longer metal shaft.. So I replaced it.. And I enlarged the hole slightly.. Just enough the 3 arm could go through and turn freely. Worked for 16 years after that.
    X2
  • You can replace that turn table motor fairly easy,I have done 3.
