Mixing two oil wieghts
mr__ed
My Toyota minivan calls for 0w-20 motor oil. I have one gallon 0f 05-20 synthetic oil and one qt of 0w-20 synthetic oil. I believe the crankcase holds about 6 qts. Since I won't be travelling in extremely cold temps, I think I'd be OK with mixing the 2 types. I'm not sure if the mistake is mine or the vendor's. I don't have time to exchange the 05w-20 oil for 0-20. Any advice is appreciated. Thanks
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
23 REPLIES 23
Ivylog
Buy the correct oil.... There's a reason the factory chose 0w-20. :S
Yea, the reason is to squeeze 0.1 more MPG out of the car.
Upgraded with a 08 HR Navigator 45โ€™...
Gulfcoast
RV'ing since 1960
Dodge Cummins Diesel
Mega Cab
Jayco Travel Trailer
jfkmk
You said the crankcase holds 6 quarts and you had a gallon plus one quart, so you're a quart short. You also had time to consult with your mechanic regarding the oil. Since you'll need another quart anyway, why not just buy the correct oil?
philh
What 3T said.
Otherwise, I'd rather go with 5w30 anyway.
3_tons
Due to only a small deviation I think youโ€™ll be just fine...On the other hand, on newer engines its best to stick with the manufacturerโ€™s specs due to the requirements of VVT hydraulic cam phasers...In this case the oil also acts as a hydraulic fluid.
mr__ed
Thanks for the replies. My mechanic also feels it will be OK to mix the two since my vehicle's specs call for 0w-15 if 0w-20 isn't available. So, looks like I'll be OK but I'll be sure I get the right oil next time.
time2roll
Either way will not matter. Mix will not matter. 10-30 would run fine too but your mileage might drop slightly. And yes I have run them all and mixed them all. Although don't go crazy with 20w50 or straight 40 weight.
MFL
Nomad II
Nomad II
I would not mix brands of oil, but if the same brand, both synthetic, I would use it.
Jerry
2oldman
Google: mix oil weights
