Jan-07-2022 04:09 PM
Jan-08-2022 06:16 PM
Jan-08-2022 06:09 PM
Skibane wrote:msmith1.wa wrote:
Here is one
Not always from heaters either.
There is NOTHING in your article that cites an example of someone being killed by CO from a catalytic heater in an RV.
Millions of people own and use RVs. You'd think that if CO deaths from catalytic heaters in RVs were a problem, there would be a least a few news stories about it.
Where are those news stories?
Jan-08-2022 06:04 PM
Here is one
Jan-08-2022 05:52 PM
msmith1.wa wrote:Skibane wrote:pianotuna wrote:
And you are willing to apply for a Darwin Award on the basis of a 25 cent sensor? No Thanks! When is the last time the sensor was tested?
Let me guess: You're one of those people who wears 3 face masks while driving alone...
Typically, the CO sensor self-tests itself - and the detector also has a manual test button. Most models have a running time counter that disables the detector and sounds an alarm after enough hours have accumulated to degrade sensor accuracy.
If it's really that much of concern to you, install two CO detectors - or three, just to be extra, extra-sure. They're dirt-cheap, and readily available.
You'd think that if there was a significant danger associated with catalytic heaters, there would be at least one published news story about some hapless RVer being killed by one.
They've been sold for many decades. Camco sells a boatload of them.
Where are all the stories about death and carnage?
Here is one
Jan-08-2022 05:43 PM
msmith1.wa wrote:
Here is one
Jan-08-2022 04:24 PM
Jan-08-2022 04:17 PM
howardwheeler wrote:
I don't fulltime but I like to camp offgrid whenever I can. My furnace seems to be properly sized. When its cold out (20 degrees) it will run maybe 60% 0f the time. The coldest I've been is around zero and that ran 85 to 90% of the time. Looks like I need to live with it.
Jan-08-2022 03:55 PM
Jan-08-2022 03:47 PM
Jan-08-2022 03:33 PM
Jan-08-2022 03:20 PM
Jan-08-2022 03:03 PM
Jan-08-2022 03:01 PM
pianotuna wrote:Skibane wrote:pianotuna wrote:
Hi,
The platinum cat vented catalytic heater is yards more efficient.
I'm not even sure they're selling those any more.
There is a website, but it doesn't have any info on where to actually buy one.
ETA: Apparently, someone is still selling them on a built-to-order basis.
Camco and Mr. Heater make unvented catalytic heaters that are readily available - and they are even more efficient than their vented counterparts. They don't require any electricity, so there is no drain on your house batteries while dry-camped.
I use the Camco 3000 BTU model in my little 17-footer, and like it immensely.
I will not use an unvented combustion heater. My daughter is a CO survivor.
Jan-08-2022 02:40 PM
Jan-08-2022 02:32 PM
3 tons wrote:howardwheeler wrote:
What is the two speed model number? And yes, my concern is when I boondock.
Hydroflame model 2H2C, 15/22 btu
3 tons
