Also, even when you're not inside the RV during periods of exteme heat ... it's not good for the interior materials and appliances to be exposed to high heat hour after hour. High heat eventually destroys adhesives, plastics, dries out materials, etc., so the inside of the motorhome should be kept below 90 degress or so at all times, anyway.
Once while staying only a few hours in obscenely high heat in the Texas Panhandle during August in our motorhome, we found that running both it's ducted air conditioning and the cab's air conditioner (by idling the main engine) cooled down the entire coach in a real hurry. Motorhome cab air conditioners are usually much higher capacity than motorhome roof air conditioners.
I'm not a fan of swamp cooling for only cooling purposes. I believe it's main advantage is lower energy costs in the low humidity areas where it can be used. If you can afford it, I recommend increased air conditioning capacity .... which of course allows for greater camping flexibility in that if you ever want to stay comfortable in both high temperatures and high humidity conditions .... you can with adequate air conditioning capacity.
2005 E450 Itasca 24V Class C
