BFL13
Aug 14, 2018Explorer II
mike-s wrote:BFL13 wrote:Not much point paying for MPPT then using parallel panels, though. I was talking about common, real world systems.
I see what you mean, but if your example started with the two 12v panels in parallel with an MPPT controller, then the type of controller would be the same in each case.
Yes, but the wording seemed to suggest the cause was the controller type and I just wanted to make that go away and leave the reasons as you meant, which I hope is now all clear.
