โMar-20-2021 06:34 AM
โMar-24-2021 09:44 PM
โMar-22-2021 04:53 PM
โMar-22-2021 04:42 PM
โMar-22-2021 02:12 PM
1L243 wrote:good idea.Darklock wrote:
Thanks everyone for the input. I have checked with Gulfstream, and was told that my roof is 3/8" plywood covered with rubber membrane. Yes, these are 2-100 watt panels. I have decided to go ahead and use well nuts 3/8" x 1". these are supposed to work for material from 5/16" to 5/8". My kit includes their Z-brackets, so that is what I will use.
I have read to put Dicor sealant around the hole before inserting well nut, as well as Dicor over the bolt head when done.
Panels are arriving later this week. Hoping for the best.
Get some 3/8" OSB plywood and practice with the well nuts and make sure your happy before application on the trailer.
Be careful not to get the membrane caught in the drill bit when drilling 3/8 is a pretty big hole.
โMar-22-2021 01:34 PM
โMar-22-2021 10:03 AM
โMar-22-2021 06:30 AM
โMar-21-2021 06:17 PM
โMar-21-2021 03:52 PM
โMar-21-2021 01:17 PM
Darklock wrote:
I have ordered some solar panels to put on my TT. I bought the 200 watt kit from Renogy. I doubt that I will be able to determine where the structural members are, so there is the very real possibility that if I just use screws they will only be into the plywood decking. In any other applications, I would trust this, but not for going down the highway at 60mph. Therefore, I am thinking of using expanding well nuts. Good plan? Or does the collective here feel that the screws should be enough?
Also, what is best sealant to insure no leaks? No clue what the roof surface is. TT is a Gulfstream Conquest.
Bil
โMar-20-2021 07:03 PM
Bil
โMar-20-2021 12:55 PM
Housted wrote:
I have 8 solar panels on my 5er. All are held on with Z brackets and coarse ss screws. The screws are driven through a blob of dicor and then the screw head is covered with dicor. No holes were drilled for the screws so they hold very well. Been like that for years.
BTW if you use double side tape you are depending on the glue holding the rubber roof on. If you use the tape on the frame of the panel you can maybe get enough to hold, but you then have no air circulation under the panels, so they may overheat in the summer sun.
Housted
โMar-20-2021 11:16 AM
โMar-20-2021 10:32 AM
โMar-20-2021 10:02 AM
Darklock wrote:Screws work well for me. And lots of Dicor. Still on my roof after 15 years.
