For those of you with rooftop solar, how do you mount the panel to avoid leaks? How do you route the cable? Where do you put the controller? Where does it actually wire in (which side off th...
Mounted ours like noted above using Dicor Self Leveling below the bracket, then above it to seal all including the screws.
Using the wall between the bathroom and living room in our fifth wheel where the 1 1/2” abs vent line runs, drilled a hole in the roof to run the wire down the wall and into the basement pass through area. Located a combiner box on the roof to connect three roof panels, then sealed it with Dicor. Three years and no leaks
