waynefiExplorerFeb 05, 2019Mounting solarFor those of you with rooftop solar, how do you mount the panel to avoid leaks? How do you route the cable? Where do you put the controller? Where does it actually wire in (which side off th...Show More
time2rollNomadFeb 05, 2019Dicor seals the holes.Cable routed down the fridge vent.My controller is in the front storage compartment.Wired direct on the battery terminals.Suitcase solar would be too small and a pitn the entire time I camp.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
Related ContentSolar Panel MountsSolar Portable or MountedSolarRoof mounting solar panelmounting solar panel
