halhawkins
Oct 31, 2022Explorer
CA Traveler wrote:
Connect the AC/DC converter which should be a 3 stage charger directly to the batteries. Unlikey the alternator of wiring can supply 30A. DC to DC chargers are used for limited battery charging and boosting the voltage.
30A + for lights? Are you using LEDs?
Normal flooded battery discharge is 50% which is 115AH for both. Flooded battery voltage tapers down with discharge. For your application consider 4x GC2s like Trojan at 220AH each for 440AH or 220AH total, or maybe 6x. Lithium batteries are likely much better for your application since they have no voltage sag until about 20% charge left.
Perhaps you should consider a larger gen or 2 in parallel. 2 2000W gens would provide 4000W and perhaps run the A/C at the same time.
Yes LED. From what I've calculated the strips at 60 led/m uses about 11W/m so that would be about 54a at 58m in length.
I can't find Trojan GC2 in 12v. Are you referring to the 6V in a series/parallel connection?
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
