CA_Traveler
Oct 31, 2022Explorer III
halhawkins wrote:54A is huge and will require multiple wires to the lights. Likely more practical to use 4x 50' strings with 120VAC. Are you sure the LEDs use 12V vs some other voltage?
Yes LED. From what I've calculated the strips at 60 led/m uses about 11W/m so that would be about 54a at 58m in length.
Don't know what equipment you're running etc but heavy draw 12V equipment draws 10x the amps than 120V and needs larger wire.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
