BFL13
Feb 01, 2019Explorer II
The 250 8D took 63 AH to refill, where 68 plus some for heat was expected. This shows further that this test was "problematic" in exactness.
It did show that the smaller battery does not go flat, and that they stay "fairly even" to "good enough" standards (IMO, or at least in my case for how I do things)
I believe the issue with my test is mostly heat loss while recharging. Different in the big 8D from the little 27 and where they are also different brands and construction. Also Puekert is in there somewhere. Wiring too.
Members are invited to run their own little tests for this to see what they get.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
