CT_WANDERER's avatar
CT_WANDERER
My Solar Project is Done
I have installed the last set of solar panels today. I now have 5 X 120 Watt panels(600 Watt Total) feeding my Morningstar T45 PWM controller. See how this works later, when we start our fall traveling. For now, parked on the pad at home I am in the shade most of the time. But it has cranked out 58AH if I move the MH forward a little to get it in some sun and if I bring the battery bank down. And that was with just the 360Watt system.
After this fall travel I might have to look into adding a larger inverter system. Right now I am running with two 300Watt inverters.
Gary
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
