rcksblr
Aug 25, 2020Explorer
time2roll wrote:
I would not mix the lithium with the other batteries. I would replace ALL the house batteries with lithium. Otherwise you will be managing two different banks with different charging etc. Verify the charging system specs match the lithium battery before you purchase. Even with the increased usable capacity you may still need to increase capacity until you are comfortable withe the power duration. I would want capability of 48 to 72 hours minimum between charging even if you charge daily. This capability for if something goes wrong. You will know more what you need after a few nights off-grid.
This is something I was going to ask separately. Kudos to you! I'm not expert on this subject so it crossed my mind to change them all for the very reasons you mention. I like the idea and piece of mind knowing we can go some time with just batteries. Just this last trip I had to pull the carb off my Onon generator because it stopped running. Choke was sticking. But boy to replace all the batteries to Lithium that a pretty penny when the batteries cost $900 bucks! Thanks for the input here.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
