VilleDeal
Jan 24, 2020Explorer II
I have now tested the limit switch and it is closed as it should be.
I have also tested the off/reset switch and have resistance when it is on reset and have no resistance when it is off which should also be correct.
I do have 12 volts to the board, so am I to suppose I need to replaced the circuit board at this point do you reckon?
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
