โJan-24-2014 07:07 PM
โJan-30-2014 04:16 PM
โJan-30-2014 12:11 PM
โJan-26-2014 07:21 AM
โJan-25-2014 07:45 PM
โJan-25-2014 02:50 PM
greenrvgreen wrote:
Since the OP did not mention cost concerns and did mention "quiet", I would agree with the recommendations for the very large Honda or Yamaha. Be aware these are big, heavy and costly, and "quiet" is a relative term.
My "suggestion" would be that the OP catagorize his power needs for the RV versus a power outage at the home. With this in mind I think two generators would actually serve better. For example, a 3k inverter gennie for the RV, and a Champion 3500 for home backup. This would give greater reliability for home backup and both gennies would stream a combined 5000-6000 watts.
Added benefits are easier portability, more flexibility in setup, and reliability through redundancy. I have a Powerhouse 2700 inverter gennie that goes with the TT, and a Champion 3500 that stays at the house faithfully awaiting the next call for home backup.
โJan-25-2014 02:49 PM
Dusty R wrote:
Why not get your home set up for a generator using a transfer switch, then add a receiptical to your home to plug the rv into?
Dusty
โJan-25-2014 02:48 PM
mrekim wrote:
Do you expect to be able to purchase and/or draw from stored gasoline during an outage?
You may want to decide how much you value the option to run on Propane/Natural Gas - especially if you already use one of these fuels at the house.
This would be valuable during a large regional outage where gas stations can't pump and those with generators can't get fuel. This happened to us during hurricanes Sandy, and Irene.
โJan-25-2014 01:58 PM
โJan-25-2014 09:14 AM
โJan-25-2014 07:49 AM
โJan-25-2014 06:50 AM
โJan-25-2014 06:45 AM
โJan-25-2014 06:08 AM
โJan-25-2014 05:28 AM
