Rockinfigs
Jul 13, 2022Explorer
Need help with ac
I have a 2020 eclipse attitude 5th wheel with two ACs. The front bedroom dometic ac is not ducted and all the switches are on the ac itself. I ran the ac for approximately 5 hrs and noticed the fan wasn't blowing as hard towards the 5th hr and sounded like it was having a hard time spinning. . I tried to put it on med or high speed but the fan speed would not change. The air was still somewhat blowing cold. So I turned it off and let it sit for about 30 minutes and observed more water dripping down the side on my rv. After letting it sit for a bit I turned it back on and the fan ran normal. I turned it on med and on high speed and they both worked. What would cause this
