Mattyd
May 08, 2016Explorer
Need some help on a solar issue
So we have a new 2016 AF 990. Ordered the factory 100 watt solar option. I keep the camper on my truck and store in a pole barn. So yesterday I had the unit out of storage to clean and load. All went went. When I took back to the barn last night I heard a shrill whistle sound and dismissed this due to the high wind figuring it was an edge of barn siding causing the noise.
So today I bring it home to work on some more. When I take it back, I hear the same shrill whistle again, but no wind. So I walk around and the unit and for sure it is coming from the AF. Drivers side, about midway from front to back. I then decide to open the back door and for sure...it is coming from inside. So I move the slide out and it is coming from the Zamp Solard Charge Controller. I messed around wit this and that and nothing changed. I pulled the truck back out of the barn and the noise quits. I figured this as I didn't hear it all day as I worked around it.
So only when inside the barn does this sound go off. Suggestions on what to do next? We are to go camping this weekend but if it does this at night, there is no way we will be able to tolerate the alarm sound.
Thanks in advance for your input.
