Almot
Jan 13, 2016Explorer III
mchero wrote:
OK, I'm out in BLM country and I'm strictly solar so I'm cranking up the absorb rate as per this Interstate site.
The Xantrex will only bring the batteries up to 14.8 (60 deg). Not ANYWHERE near the Interstate's 15.3 volts!
Batteries in Absorb now & hovering around 15.3 to 15.5. will see what happens later this afternoon.
Interstate in your link suggests Absorb 14.7V - not 15.3V. You're boiling them at Equalization now, wasting fuel and polluting the air for nothing :)
The fact that solar controller can't bring the batts to 15.3 Eq could mean several different things: not enough sun, bad battery, temp comp doesn't work - to name a few.
