โJan-24-2018 06:27 AM
โJan-24-2018 07:13 PM
MrWizard wrote:Yes, I see that the Powerverters have a current sense system and shut off when power is not being drawn. I will probably end up with Master battery switch for it that can remove 12V power from the inverter. Thanks for your input!
i don't have the remote pendant
never needed it
the inverter is on full time, unless i'm working on the batteries cables
it has a load sense feature, adjust it for the smallest load, you will use
(fridge light ?) and the idle current will be minimal
I would recommed you try to google the manual
โJan-24-2018 05:25 PM
โJan-24-2018 03:46 PM
โJan-24-2018 03:01 PM
GordonThree wrote:The transformer in this must be a monster. Mfg states unit is 39 lbs but it feels like a heavy 40 lbs. :@
3000 watt overload for an hour, that's impressive. Good sign that it's overbuilt on the inside, heavier fets and good cooling.
Nice gift!
Mr Wizard wrote:
I have the 1250 and it has performed flawlessly for 7 years
Make coffee in the morning, run the MW, vacuum, etc..
Industrial quality, designed to run motors for years
โJan-24-2018 09:29 AM
โJan-24-2018 09:03 AM
โJan-24-2018 09:01 AM
โJan-24-2018 07:48 AM
BFL13 wrote:
This one?
https://invertersrus.com/product/tripplite-pv2000fc/
Not too clear whether one of the two outlets can do all the watts or whether each can do half. You can ask their tech support.
Be worth finding out the shut-off voltages for high and low. Typical would be 10.5 low (alarming at 11) and 15 high.
It is good that it is rated to run induction loads too. Note that some few things don't like MSW, such as electric blankets. Most things will run ok including newer microwaves.
โJan-24-2018 06:41 AM
โJan-24-2018 06:35 AM
