New Stereo/cs-dvd unit install
traildog
My wife and I think we found the perfect TT for us and have pulled it 5k plus miles so far.
Now it’s time to upgrade some things.
The audio unit that came with it is junk. The speakers are wired left channel bedroom right channel living room….stupid.
I’m going to wire them for left and right channels in both rooms and install a switch so I can chose between all speakers or just 2.Furrin junk
My question is, have you replaced your stereo system and what did you buy? I’d really like it to fix the existing hole.
2021 Coachmen Freedom Express Ultra Lite 259FKDS.
2021 Ford F-150 3.5 ECO BOOST 4:30
15 REPLIES 15
prichardson
First. It appears from your link that when you connect the speakers properly your unit can select between living room or bedroom but not both together. As to replacement fitting existing hole; if the unit you ultimately choose is smaller than the existing you can make a blank off plate.
