CabinetGuy's avatar
CabinetGuy
New Toilet splashes out of back when flushing
We just purchased a new Toy Hauler and took it out this weekend for the first time.
I noticed yesterday that the toilet had some water behind it so I investigated and found that when I release the foot lever, the valve spits water out of the back of the toilet towards the top. I took the seat off and see that there's a valve that has a hole, or vent. This is where the water is coming from.
I did a little research and figured it was too high of water pressure so I filled the holding tank and ran off of the water pump but it does the same thing.
Any suggestions on how I can fix this? The pedal seems a bit stiff, but not overly. When releasing the pedal, it makes a definite suction type close which is when it spits the water. You can't ease your foot off as it pretty much slams shut when within the last couple of inches.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
