No 12 V juice--battery or converter?
coolmom42
My new-to-me 2014 Coachmen C (21QB) has no 12 V juice without the generator running. As in, the lights won't even come on. The battery is a cheapo, previous treatment unknown. When I looked at it prior to buying, the generator was running, because it was a really hot day & I wanted to make sure the AC was working.
It's possible a light was left on inside the first day I got it home, too. That may have flat-lined the battery in a couple of days.
If the 12 V systems work when the generator is running, does that mean the converter is working?
If the 12 V systems work when plugged in to 110 V, does that mean the converter is working?
The generator hour display has a tiny battery icon and as best as I can see it shows a symbol of a battery charging (zigzag in the icon.) Does that mean that the generator is charging the battery?
What battery does the generator use to crank up? It starts just fine.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
19 REPLIES 19
mchero
bikendan wrote:
jaycocamprs wrote:
But be aware that there are likely still a few things (like the propane detector) that draw electricity even with the disconnect switch "OFF". So for long term storage, disconnect the negative battery cable.
Or install a battery disconnect switch right on the battery. I did and my dual batteries were still nearly fully charged after 4 months of storage.
Good idea!
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
bikendan
jaycocamprs
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
coolmom42
MrWizard wrote:
Problem solved ... Learning experience acquired
Definitely. It doesn't help that the switch labelling is in microscopic letters in a poorly lit location. But now I know which position is for disconnect.
enblethen
Thanks for the update!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
coolmom42
MrWizard wrote:
The disconnect
Is for disconnecting the house from the batteries when the RV is stored and Not being used and not on Shore power to maintain the batteries
The connection between chassis and house is normally open and connects automatically only when the engine is running,
From your description the house/RV is completely disconnected from the batteries, they are not being charged, you need to put the disconnect switch back in use mode, it should not drain the engine/chassis batteries
The generator or a large inverter are things that would be connected directly to the batteries and not go thru the battery disconnect relay
You were correct. The switch was turned to the OFF position! DUH.
I was previously a partner in a TT that did not have a disconnect switch.
MrWizard
Moderator
Moderator
The disconnect
coolmom42
MrWizard wrote:
Sounds like the converter is working
Try this test
With the generator on and you have 12v power
Flip the the battery disconnect switch several times
The latching relay might be stuck
Or if the batteries are discharged the latching disconnect relay might not have enough power to engage
Check to see if the batteries are getting charge voltage
Somebody will post where the relays are located
And any fuses
Generator can be wired chassis or house
The Onan in my RV is wired to the engine battery
Thanks!
More questions:
OK does the battery isolation switch totally disconnect the battery from the RV? For some reason, I thought the disconnect was between the house battery and the chassis battery, so you couldn't run down the chassis battery and be stuck. I googled around and found differing info. Can you clarify this for me?
coolmom42
midnightsadie wrote:
find some body close to you that has a rv get them to walk you threw things. better than throwing money at it. then finding out it was a simple fix.
I'm fairly proficient at most things RV. This is my first RV with a built-in generator and an unknown battery.
mchero
Double post
Robert McHenry
mchero
Dusty R wrote:
How does a load tester work on a dead battery?
Silly Question......
You fully charge the battery then load test it. If it won't take a charge or fails the load test it's toast.
Robert McHenry
enblethen
Dusty R: It doesn't! Does it? OP must try to charge it first, then attempt a load test. I fop has a battery separate battery charger, he or she could try charging battery.
Bud
USAF Retired
Pace Arrow
Dusty_R
