smpsmpsmp's avatar
smpsmpsmp
No electricity in RV
My 5th wheel (Winnebago Lite5) was parked for a couple of months at my home. It was connected to shore power with surge protector. Fridge quit working so had a new one installed and it worked great parked in the driveway. On this trip, turned on fridge using propane and the wires were burned. So, fridge isn't working now. The wires were then disconnected. I now have no power in the trailer. I've flipped the circuit breakers. Any ideas? Also, any idea if fridge rewriting will be a huge deal? Thanks!
  • wa8yxm's avatar
    wa8yxm
    YOu have two power systems in the RV, 12 volt (Really 13.6) and 120 VAC.
    Are BOTH systems down? or just one, if so which one
    12 volt runs lights, Water pump, Furnace, Slides and jacks, and control power to Water Heater, Fridge and A/Cs (in most cases, nto all)
    120 volt runs A/C.s Electric side of water heater and fridge, Microwave and TVs.
    Some RV's have a 3rd (inverter) systrem, this is where 12 volts run 120 volt ac devices (usually just the TV but mine also runs the Microwave)
    OFten, as you comn off the battery, there is a fuse or circuit breaker (Required in fact) this fuse or breaker may be a bit hard to find, if a breaker may be self-resetting or manual reset. Follow the wires. (Assuming it is the `12 volt system out of comission).
  • Bobbo's avatar
    Bobbo
    Start at the pedestal, power? If no, you have your problem.
    If yes, check both sides of the RV's main breaker, one side should have power. If no, the problem is the cord/connections between it and the pedestal.
    If yes, the other side should have power. If no, the breaker is bad.
    If yes, keep going down the line checking every connection until you find where you have no power. The problem is between the last "power yes" and the first "power no."
  • LP fridge still needs 12v from battery/converter to power the controls
    sounds like something in the power control center
    a loose connection on the 120v input power ?
    rewiring for the fridge is going to depend on what wires burned and why
    and how hard to pull new DC power wires from the power center to the fridge
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
