MrWizard
Mar 27, 2022Moderator
Jbarca,
Thanks for the pictures, I can pry the cover enough to peek inside and can see the line connected to the output at the top of the WH, the line has a plastic fiting with finger wings,.
But I can't get my hands in there yet, and was Not able to.get a picture , going to make another attempt shortly
Richard I hope your water heater is easier to get at.
Because
If you have a 36S like this one, your in for a heap of frustration,
I'm turning off the propane, letting the fridge burn it off, then use the angle grinder to cut the cover plate,
I don't have air tools & chisel, and the saw blade on the multi tool is not up to the cutting job on this steel plate
This should have been a simple job with minimum hassle,
It has been everything but that, with one obstruction after the other
Because
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
