EMD360
May 13, 2021Explorer
No power to backup lights
We noticed the left backup light was out but the right was functioning. It was not a bad bulb. I pulled the socket and disconnected it and had no power to the light. Water was definitely getting into the light socket as there is some rust on it and the cavity was wet. It looked like the rubber gasket still had the protective paper on the coach side! I thought that somehow I might tap into the power to the other light so I disconnected it and blew the fuse at some point. I reconnected it and replaced the fuse but it still doesn’t light. I read that there is a reverse switch on the transmission but I don’t see reports of that going out on a 2018 model. I’m not sure I can find the switch as I’m not finding a late model E350 diagram to see where it is located. All this is a pain because it’s reverse and so to keep from being run over someone has to be in the driver’s seat in reverse but on the brake with the emergency on. Any hints will be appreciated.
