Boon_Docker
Mar 22, 2022Explorer III
BFL13 wrote:
2003 Komfort 5er had Suburban WH
Had to replace that red light switch.
ISTR it's wires went to a small white box with ? fuse? then wires to WH. Was a reset on the WH outside too
I forgot about the reset. I had to keep resetting the T-stat/thermal cut off until it finely decided to give up completely.
Easy way to check it is remove the cover and the two wires and check for continuity with a VOM.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
