Silas_Carpy's avatar
Silas_Carpy
No water pressure
2009 fleetwood pulse, dewinterizing. Drained holding tank and low point valves. Filled tank half way, turned pump on pumped up pressure and stopped. Flush toilet pump and water run. Turn on shower, hot and cold, pump and water run. Turn on either sink, pump runs about 1 second, stops, no pressure to either faucet. Anyone have any idea as to cause?
  • Do check the sediment screen (if installed) on your pump itself. First trip out I had to dig around to clean mine out too. Was also my reminder to bleach the holding again.
  • ejmorgan wrote:
    Perhaps the sediment screens in the faucet outlets are clogged. Unscrew them to inspect and clean.
    Ed
    Likely this is problem
  • Your symptoms act like a failed check valve. Why a check valve would affect both hot and cold for only the sinks (assuming when you say both you mean bathroom and kitchen) is a head scratcher. If it is just the hot water it would be the check valve at the water heater out line.
  • Perhaps the sediment screens in the faucet outlets are clogged. Unscrew them to inspect and clean.
    Ed
  • Did you put your winterizing valves back to the normal position?
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 09, 2025
