opnspaces
Feb 06, 2020Navigator II
kmb1966 wrote:
I have been working on my Norcold 1200 again and have noticed that the unit will power up and operate when only connecting the 12 volt (+) supply to the rear control board connector labeled "12V". The connector labeled GND can be disconnected totally. Obviously there refrigerator is somehow already grounded somewhere, but I am wondering if this is a problem or is normal??
I think you all missed the question "Is this a problem or is it normal?".
No it is not normal which you can gather from all the responses trying to help you figure out how it's possible. But is it a problem? Probably not but I guess that's where you have to define your meaning of the word problem. Should the actual ground be fixed or attached? Absolutely.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
