09FLSTC
Jan 23, 2015Explorer
Norcold 1210 quit cooling
Not a problem for 8 years since 2007. Just quit. Green LED light is on. Flashes AU--AC when you press the mode button which means automatic mode, AC available but doesn't switch to AC solid and come on. Burner does not light. Then......switch manually to LP and the flames lights, stays lit all night but no cooling.
Before, when I selected the mode button, it would start searching for AC and if not available, would switch to LP. Does not even try to do that now unless I switch it.
I have the service manual but don't have my multi meter with me, arrr.
Any similar out there?
In Edit, recall mod has be done.
