MNtundraRet
Jan 09, 2024Navigator
It is not unusual for any refrigerator to have a slight vacuum. it is normally caused when there is moisture inside the RV. If you push in against the door that is sealed that way it should help release the vacuum and allow the door to open. A small flat screwdriver can be pushed between the stuck gaskets to relieve the vacuum if needed.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
