BFL13's avatar
BFL13
Jan 04, 2020
Norcold 641 Moisture Reduction Heater Question
Just got a used 641 installed and going. Have a question about this heater mentioned in the manual. That says it is in the centre divider between the doors and operates only when the fridge is ON and DC power is sufficient.
I remember posts on here about ISTR Dometic fridges that have a switch in the door that you can turn this feature off, but that might not be the same thing?
Also, there is an optional "Low Ambient Heater" with 3 amp fuse you can pull, but looking at Google for this, I don't seem to have one.
Questions are:
1. Can the moisture reduction heater be turned off, and how?
2. How many DC amps does it draw when on?
I ran the fridge to see the amps on the Trimetric, and got:
A. LP--burner lit- 00.7 amps
B. AC-- 00.5 amps
C. LP--door open, light on--1.1 amps
I don't know if it would be worth turning that heater off when off-grid. If answers to above come in, then I will know.
Thanks
  • Seems similar to the ARP as I mentioned earlier. Can't say if the heater is necessary in sub-freezing temps, or just helps. The heater stuff is on the back of the fridge that faces the cold outside, so I can see it could get cold alright.
  • Old-Biscuit wrote:
    Low Ambient Heater is for 'cold/freezing' camping
    It is a heated wire that is thread up/attached to cooling coils to keep the 'coolant' warm so fridge will operate in sub 32*F temps
    The .3 in your model (N641.3R) indicates a DC Heater (30A)
    The 'R'-----haven't a clue
    Well ... how often are the interiors of RVs at those low temperatures such that their absorption refrigerators are also exposed to those kind of low interior temperatures surrounding them?
    I have a good old Norcold 611 in our Class C and it even helps to keep the cabinet around itself warm from to it's system electric or propane heaters whenever it is cycling/operating.
    I can see an absorption refrigerator having problems operating in cold temperatures in, say, a shed out in the backyard in winter ... but inside an RV that is normally kept warm enough for us humans?
  • Hi BFL13,
    From the cold weather camping thread. "Norcold now make (and install on all new Norcold refrigerators), a "Cold Weather Kit" (Norcold part number 634913) that will allow the refrigerator to safely operate down to zero degrees (f I guess).
    https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/24160748/srt/pa/pging/1/page/11.cfm
  • Low Ambient Heater is for 'cold/freezing' camping
  • Thanks! So not enough to worry about.
    BTW, the thermal switch in this case seems to be part of a "Low Ambient Heater kit, that goes in the back cooling "chimney" somehow in the Goolge info. (I will edit the OP for that, sorry)
    It is a resistance heater. Has +12v black wire through a 3a fuse, and a -12v BR wire though a thermal switch. The manual just says it is for cold weather to help with heating. It might also be whatever an ARP is, I am not clear on all that. I don't have one AFAIK.
    641.3R What does the R stand for? Can't find a list of options that might refer to.
  • NO..there is NO On/Off Switch for the Moisture Reduction Heater'
    It is ON when Fridge is ON
    .11 to .17 amp draw
    Automatic Ignition .50A
    Interior Light .60A
    Gas Valve .14A
    3A thermal switch would be for Ice Maker/////water line heater
Having RV issues? Connect with others who have been in your shoes.24,281 PostsLatest Activity: Jul 11, 2025
