Big_Katuna
Nov 28, 2018Explorer II
dougrainer wrote:Big Katuna wrote:
Shouldn’t be rusty yet but clean/ check flame height, clean flue.
Get infrared thermometer and establish actual temps on elec vs gas.
You NEVER use a IR thermometer to verify refer or roof AC temps. In a refer you put in a glass of water. After 24 hours you use a digital thermometer to measure the water temp. That tells you the actual cooling of the refer. Doug
I’m having no luck balancing a glass of water on an ac duct.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
