buckarooman's avatar
buckarooman
Norcold n510.3
Hello I have a norcold n510.3 refrigerator and I keep getting a weird fault code that I can't seem to look up,on the front panel were you have the green light that shows what mode youre in shows a single green dash in the middle. It appears that it can't switch automatically and gets hung up on LP and 8n order for it to switch to a/c you have to shut the refigerator off then it will select auto a/c. Any ideas?
  • Just pulled the out side cover off to inspect fuses and the red 12v jumper wire has been rubbed bare what do you think about this being my gremlin?
  • Are you sure fault code is just a single horizontal line-----mid line and NOT a lower case 'r'
    Lower case 'r' is AC Relay Stuck Closed. Power board failure
    Have you used the 'Diagnostic Mode'......check out Screen 4 (Stored Fault History)
    AC Relay Stuck Fault is vertical line lower right side
