1_tired_dog
Jan 18, 2014Explorer
Norcold N841 Blowing Fuses
I have a first time problem with a Norcold N841 blowing the 5 amp fuse on the control board. It blows as soon as i plug the 110 power source in. The OHM reading is 34 between the two black wires of the heater leads. I am seeing some yellow residue around the LP burner, which I understand is an indication of really bad news. Do I just need to bite the bullet on a new unit or cooling unit, or could it possibly be a case where i could replace the board or heater or just run off propane?
