gkitchens's avatar
gkitchens
Norcold On Lights Stays On With Frig Off
My Norcold Model N843 refrigerator on light stays on after the refrigerator is turned off. If I push the on/off button, then the refrigerator starts in one of the modes. I am sure the refrigerator is off because I open the door and the light is out. If I turn the master switch for my house batteries off and back on then the on light stays off. Is this something a hard reset would fix?
    No, a hard reset is ONLY for a NO CO condition, nothing else. You probably have a bad optical board(this is the inside push button display). Doug
  • So does my Dometic.
    If you have the hidden magnetic switch then you may need to pull a fuse to keep it off.
