Pangaea_Ron's avatar
Pangaea_Ron
Norcold Refrigerator makes odd noises starting on propane
When I fire up the Norcold double door refrigerator/freezer on propane it makes a loud "glub, glub" sound before it reluctantly starts. It does not make that noise when started on 120v AC.
It also shuts down occasionally when driving in a crosswind, and the alarm sounds.
Any thoughts?
  • I had something similar and turned out the gas burner had deteriorated a bit and a new one fixed the gurgling and made the flame burn much better (blue with nice shape). I never lost the flame but without the proper outlet at the end of the tube the shape of the flame was incorrect.
    This is what the part looks like (this will or likely is different for your model).
    Norcold Burner
    If that's the problem you might see it by looking up into the burner tube.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
