Norcold replacement
mac51
Fridge on blink- Has anyone changed out their refrigerator themselves or had it done?. How hard was it, any problems. Ours (Norcold N821) won't cool or freeze. Controls function, burner ignites but no cooling and freezer mildly frozen. 16 years old I guess time. Like to install myself hopefully it will fit thru door. Anyone try it or should I delegate it to a dealer. Thank you for you thoughts. Mac
2002 HR Vacationer 32pbd Ford V-10
Davis Tru-Trac/Bilsteins
Henderson rear trac bar
2016 Equinox V-6
12 REPLIES 12
turbojimmy
Another vote for replacing the cooling unit. It's not that hard. I did mine inside the rig though it might have been easier (more room) if I had taken it outside. The kit I got came with the thermal mastic sealant and foil tape. The replacement cooling unit works great. This is my 5th season with it. During last weekend's trip it kept the fridge at around 30 degrees and the freezer 15-below zero. That was on electric. It gets colder on propane.
1984 Allegro M-31 (Dead Metal)
ljr
I replaced mine a few weeks ago. No rocket science but a heck of a lot of grunting and groaning.
Larry
mchero
Any signs of a leak on the backside?
I replaced the cooling unit on ours 3 years ago from rvcoolingunits.com. Still going strong. We boondock so wanted to keep norcold.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
Happytraveler
2 months ago we replaced our small 15 year old Norcold Fridge. After two years getting it fixed we couldn't trust it anymore. Dang, the cost was around $2,400.00 installed.
Charlie, a male Soft Coated Wheaten Terrier
Katie, a female Soft Coated Wheaten Terrier
mac51
Good ideas have me interested in the new Amish units. Fridge is still nice just quit cooling when we got the MH out to travel. thank you for the reply's so far. I'll keep watching
2016 Equinox V-6
neschultz
We just replaced our Dometic DM2652 with a Magic Chef 10.1 cu ft residential fridge from Home Depot. Took a few hours but I had to increase/lower the rough opening by about 6โ€.
Norman & Janet with Minnie the Weiner Dog
2005 SunnyBrook 38 BWQS 5th Wheel (stationary in FL for snowbirding)
rhagfo
Another great place to get a new cooling unit. I have bought two from them for two different RV's. Great service.
RV Cooling Unit Warehouse
Scottiemom
National Refrigeration in Shipshewana can help. Leon is a young Amish man who repairs and replaces RV refrigerators. He has replaced the cooling unit on our Norcold 1200. Works great. His website is National RV Refrigeration
A very nice young man who knows his stuff.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Big_Katuna
I replaced the cooling unit on my 1200 Norcold. Works better than factory.
Easy enough. 1200s are about $4k new, new cooling unit $1200.
Now you can buy a compressor based replacement for some models..
My Kharma ran over my Dogma.
enblethen
I changed my out. Fairly simple on removing it from hole. Big problem was I had to remove it from the rig through a sliding window as the door was not large enough.
I would be getting new unit and not trying to repair old. newer ones have better insulation.
Try to get a direct replacement so as not to have to modify opening.
While refer is out, check the top area to make sure the ventilation is correct.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
garyemunson
If the fridge is still in good shape, you can just replace the cooling unit. Easy to do inside the RV. Google "Amish RV fridge". You said the freezer gets cold? Gas fridge units either work or they don't. The cooling unit doesn't sound bad to me. Maybe partially plugged gas orifice not producing a big enough flame? Does it work on electricity?
Boon_Docker
I replaced my cooling unit a few years ago.
Had to remove the cooling unit itself from the fridge inside the trailer as the fridge would not fit through the door.
It was actually quite in easy process, took about 2 hours.
