Lynnmor
Mar 16, 2017Explorer
While I would replace them, this is what Dexter says:
Usually, light cracking of the surface of a brake lining can be expected under normal use. This is not cause for replacement. However, if the lining is deeply cracked to the shoe surface or is missing chunks, your brake linings will require replacement.
Having RV issues? Connect with others who have been in your shoes.24,277 PostsLatest Activity: May 20, 2022
